Anyone know what the cost for a B35 Rebuild would be?
  • xxx-Lost-Soul-xxx
    • Apr 2008
    • 1953
    I have decided i am going with a B35 Swap, Does anyone know what the cost for a rebuild would be? Both top and bottom end?
    I Dont have the time to my self.
  • ttrousdell
    • Nov 2009
    • 1770
    To have a machine shop rebuild a b35 for you and do all the work would probably cost 5-8000. For them to disassemble, and reassemble would be close to 3000. All new parts are pricey as well. Valves are 30 each, chain rails are more then you think. main beaings 100 for set, conn rod bearings 100 for set. piston ring set is few hundred, probably $500 in gaskets. New head, main, conn rod bolts few hundred. If they find things out of spec it will obviously be more.
    Where are you located. I have a b35
    The Build:
    • LJ851
      • 7919
      Why rebuild? B35s are just about bulletproof. I would spend a little extra to get a known condition engine with 100,000ish mileage, put a couple new seals in and rock it for another 100k+.
      Lorin
      The M30 is God's engine.
      • xxx-Lost-Soul-xxx
        • Apr 2008
        • 1953
        I want new Timing chain/guides & Main bearings. As well as Freeze plugs.
        • Grand525
          • 491
          Would you consider of buying a refreshed well running complete b35 powertrain?
          • xxx-Lost-Soul-xxx
            • Apr 2008
            • 1953
            yes i would,pm me.
            • ZenitramNaes
              • Jul 2012
              • 150
              Where could I find a write up on a head rebuild for an m30?
              '89 535i/5 Holset WH1E turbo
              Follow my m106 megasquirt build thread: http://forums.bimmerforums.com/forum...Squirt-content
              • rav320uk
                • Jun 2004
                • 1337
                The 3 chain guides new from BMW are about £46, so under $100, i bought some a few weeks ago for my B35 rebuild.
                Main bearings, shells and new piston rings, shipped from the states cam to £240 GBP so about $320
                Valves can be reground and polshed clean if they are ok,
                The thing to check on these is the valve guides for wear.
                Full H/G set from Elring is about £80, so about $130.
                It all depends if you go main dealer or not.
                If you have bought items from me, please leave feedback below.
                If you are a BUYER, Check My Feedback.:up:
                http://www.r3vlimited.com/board/showthread.php?t=183860
                Check out my Euro Build Thread
                http://www.r3vlimited.com/board/showthread.php?t=215557
                • ttrousdell
                  • Nov 2009
                  • 1770
                  I had better luck finding m10 head rebuild infomation. Same thing just 2 more cylinders.
                  http://www.bmw2002faq.com/content/view/85/32/
                  The Build:
                  • pleasefixitup
                    • 24
                    I got a timing chain (with master link ugh) tensioner guide, guide rail, and piston for about 75 dollars and free shipping.
