couple M30 swap questions
  • thejimlab
    • Oct 2004
    • 588
    Ok, I'm about to pull the trigger on an M30 swap. I'll be getting everything needed from a 91 e34 5-speed. I'm thinking I'm going to use mounts from e30.de. The car that the motor and tranny will be going into is an 84 325e. Here's my questions. The mounts have 3 possible mounting locations. The furthest back is best for weight distribution and I intend to use that one. Will e30 tranny mounts work for any motor mount positions? Also, I've read conflicting info about shifter linkage. Do I need to modify my linkage?
  • nick526
    • Jan 2011
    • 258
    Ayman's selling off a set of Good'nTight's mounts for $215 fyi. I think you can drill them to get to pos 3 and save yourself some cash.
    The trans mount bracket can be slid back or forward in the slotted channels on the unibody, no worries there. Depending on the trans you use, you may need the e30 M3 bracket though.
    I haven't come to the point where I have to figure out the linkage yet, so I can't really offer any advice there. Maybe one of the guys who've already tackled that part will chime in.
    I miss the old BMW
    • rav320uk
      • Jun 2004
      • 1337
      Pushing the engine back to Pos 3 won't affectt he trans mount, as above , they slide on the body.
      Depending on what gearbox you use, if it's the normal M30 one, you'll need an E30 325 i one, as that puts the gearlever in the right place.
      If you have bought items from me, please leave feedback below.
      If you are a BUYER, Check My Feedback.:up:
      http://www.r3vlimited.com/board/showthread.php?t=183860
      Check out my Euro Build Thread
      http://www.r3vlimited.com/board/showthread.php?t=215557
      • nick526
        • Jan 2011
        • 258
        This one?
        So getrag 260/6 + aluminum shifter rod and you're good to go?
        I miss the old BMW
        • chance
          • Feb 2012
          • 671
          Idk about the aluminum carrier, but i am pretty positive you will have to shorten it. The m30 is a long motor, and you are putting it in the rear most position. I have otis mounts and in the forward position, the shifter on my g265 was in the perfect spot, but i had to shorten it after moving my engine back.
          1991 335is in progress
          • navytapaul
            • 615
            same here, anything other than position 1 and you're going to have to shorten every thing, ie shifter, drive shaft, etc.
            • nick526
              • Jan 2011
              • 258
              No need to shorten the shifter, just use the one in the picture above and push the rear section further back through the rear bushing.
              Also, my driveshaft didn't need to be shortened. I just swapped output shaft flanges and drilled the front of the shaft out to make room for the outout shaft.
              This is in position 2 with an e34 260/6, Otis' mount brackets, and Condor mounts.
              I miss the old BMW
              • navytapaul
                • 615
                Guess I should have clarified, as I have a e28 g265 which is longer than a 260.
                • yert315
                  • 2734
                  also, the g265 uses a metal plate style shifter, rather than the aluminum one. Not much room for adjust-ability there.
                  • LJ851
                    • 7919
                    Because nobody can cut and weld steel.
                    Lorin
                    The M30 is God's engine.
                    • nick526
                      • Jan 2011
                      • 258
                      Hmm, didn't know that about the 265's length....
                      I think thejimlab is using the same trans I used if he's got an e34 donor car.
                      I miss the old BMW
                      • navytapaul
                        • 615
                        I cut a good 3/4" out of my shifter and it still needs to be adjusted. e34 didn't come with a 265, only 85 e28's iirc
                        • nick526
                          • Jan 2011
                          • 258
                          Right, so the OP can do what I did.
                          I miss the old BMW
