I charged up the battery and left the battery charger on while testing and did NOT have the throttle open and got the following numbers:
Original Test Results: (1) 135, (2) 92, (3) 92, (4) 103, (5) 105, (6) 135
*Edit per richard.bratton, I rearranged the order of the compression test results to match the correct naming convention.*
Am I in need of a freshen up with new rings and a hone?
Thought just occurred to me: I should probably get the valves adjusted prior to running the compression test, right? I would assume that would be a factor. True?
Update:
I did the valve adjustments, nearly all of them were tight with a few a tad bit loose. I didn't snap a picture but the head, lobes and all the top end (didn't check bearings) looked SUPER clean. Was very happy to see that. No varnish at all. Pulled the plugs (all of them) and was able to retest number 1 and number 2 with the throttle wide open before having to pack it in for the evening: (1) 180, (2) 110. I will complete the test another day and also do a wet compression run to see where my problem spots are.
Pretty clear to me even with an incomplete test that I will have to pull some of the pistons, rehone and rering. No biggie.
This thread can die now.
Update:
