Does anyone know if if there are different varieties of driveshafts that were used with the E34 M30's. I am trying to use the Jared Squires method for the driveshaft so that I can get it to fit. Unfortunately we seem to have very differnt driveshafts. I am not sure if the driveshaft on my car is original or not since I got the car at a junk yard. It seems as though the male/female ends on my driveshaft are switched. Anyone know of any differences on these? What have other M30 swap guys used on their cars
M30 driveshaft help
Are the M3 driveshafts and the 325i driveshafts the same length? Are either part of the standard 325i driveshaft equal in length. RealOEM.com does not list the M3 length. I was wondering because then I could see if everything lines up before I get an M3 driveshaft.Comment
azzkikr, keep us updated on the M30 swap. I'm doing one myself as of now, so let me know how things are going...
bmw2335ist, Can I use the front half driveshaft from the E28 535i? that's where the tranny is coming from....Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
Originally posted by M3fan4evaazzkikr, keep us updated on the M30 swap. I'm doing one myself as of now, so let me know how things are going...
bmw2335ist, Can I use the front half driveshaft from the E28 535i? that's where the tranny is coming from....Comment
Originally posted by azzkikrOne more quick question. What is the difference in the size of the 260 vs 265? Is the bell housing any narrower in the engine bay? Or is it just the overall length of the trans that is different?
The 260 is a one pices tranny I do not know the over all lengh but i do know it is diffrent than the 265.
The 265 is conseterd a three pice tranny the bell houseing unbolts from the tranny and the third pice is the backpart of the tranny witch is the fifth gear
Also if you are useing a m30 from i think it is 85-87 you need the bellhouseing for the motronic scensor'sComment
Sorry I meant to ask if the bell housing was any shorter lengthwise. The reason I am asking is because the driveshaft I have is about 4 inches to long. I am waiting to hear back from Jared Squires to see what he did. His site said that he was able to take the front from the 535i and the back from the 325i and then it fit for him. I am just curious what length his hybrid driveshaft was becuse if I do the same I am long by about 4 inches.Comment
Originally posted by azzkikrSorry I meant to ask if the bell housing was any shorter lengthwise. The reason I am asking is because the driveshaft I have is about 4 inches to long. I am waiting to hear back from Jared Squires to see what he did. His site said that he was able to take the front from the 535i and the back from the 325i and then it fit for him. I am just curious what length his hybrid driveshaft was becuse if I do the same I am long by about 4 inches.Comment
Hey, I just got back from LA. Ill have to get those injectors out if you still want them. Also I have the e28 shaft in my garage, so if you cant figure it out, we could compare them. Jared used the rear of an E34 shaft, and the front of the E30 shaft and then turned it backwards or something I thought?
www.rimstrader.com
all the parts you need to swap the M30 into your E30 here-> http://www.r3vlimited.com/board/show...ght=m30+mounts
99 540i/66 911Comment
Originally posted by bmwmikeHey, I just got back from LA. Ill have to get those injectors out if you still want them. Also I have the e28 shaft in my garage, so if you cant figure it out, we could compare them. Jared used the rear of an E34 shaft, and the front of the E30 shaft and then turned it backwards or something I thought?
I have A question How many people Have m30 into an e30 do you know ofComment
Well, i'll be done with mine by the end of the spring...e32Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
