pistons top
  • 4ebypek
    • Feb 2006
    • 3
    pistons top
    Can i cut the top of the piston to make a flat top piston? Thanks
  • rs4pro3
    • 5808
    You can ground it down some, what are you trying to do?
    85 325e 2.7 ITB'd stroker
    • 4ebypek
      • Feb 2006
      • 3
      i would like to put pistons from m30b34 to m10b20 block with 1.8i head, but to buy custom or je pistons is a little expensive for me.
      • rs4pro3
        • 5808
        ah ok, FYI the M30B33 block has flat top pistons, I happen to have a set for sale if your interested.
        • 4ebypek
          • Feb 2006
          • 3
          how much do you want for 4? and which size they are?
          • rs4pro3
            • 5808
            oh ya I forget they are the smaller bore, so they wouldn't fit the m10.
            • thejimlab
              • Oct 2004
              • 588
              I've heard you can run 92mm VW bug pistons, if your looking to go to 92mm.
