I scored a freshly rebuilt M30b34 for really cheap and I will be doing a swap here shortly. The only concern I have with this motor is its low compression pistons and the mild US spec camshaft. I plan on buying an IE regrind to deal with my cam woes and I would like to use B35 pistons to raise compression to 10:1 ish. Will this work? if not, What pistons can I use to raise compression in this engine? Keep in mind I'm on a budget.
OR should I just ditch the N/A idea and boost the stock 8:1 motor?
Any advice on a budget non-intercooled M30 turbo build? Im really only looking for 300hp.
