I am finally getting to the wiring on my car. I have everything hooked up and everything seems to be correct. I cant start my car though. I dont get any power to the starter from the relay. If I short the battery plug and the ground plug I get the starter to turn over. However if I try to get the starter to turn by using the key I get nothing. From my simple analysis the starter relay is initiated on pin 18 on the engine plug and the E30 chasis plug. I get voltage to pin 18 on the car harness. I just dont get anything to the starter through the computer. Are there any satefy controls in the ECU that prevent the car from starting. My engie is from a 1990 535i 5-spd and as far as I know it should just engage the starter when the key is turned.
Also what cable should go the the little plug on the alternator? I have the starter in series with the alternator. I just ran a big nasty wire across from the starter batter lead to the alternator lead. That should be fine right? But where does the little cable come from? I did try starting the car with and without the alternator connected just to be sure that wasnt causing a problem.
I do get power to the console and it lights up like a christmas tree. Pretty much every light turns on. The check engine light even flashes so I guess that is a good sign. How do you enable the check engine fault code to be displayed? I tried to do the tap the gas pedal 5 times in 5 seconds after turning the car on but I didnt get anything. I even tried open the throttle by hand 5 times in 5 seconds but I still didnt get anything. Where does it pickup the signal for that anyway. That is how to get the fault codes right?
Its long sorry.... just lots of wiring still to be done. Any pins I should switch for sure on the plug?
EDIT:
One more thing. What to do the plugs in the glove box connect? There is a 4pin plug on the E30 and the M30 wiring harness has a 4pin plug but the connectors are different. What do they do? There is also a couple little 2 pin connectors in there to...what are they for?
EDIT:
