I'm doing a 1.3 motronic conversion on my m30b34 and it requires a m30b35 harness. I was wondering if anyone knew where to get a diagram google search didnt do much.
M30b35 wiring harness diagram??
Tags: None -
i need to do the same thing -
Same here. Theres a guy on bimmerforums that sells (or maybe just used to sell, idk) a kit with everything for a decent price.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
I got everything I needed from bummerguy2002 on mye28 he sells the kits. Turns out the conversion is PITA and I'm making it easier by buyin a b35 intake manifold. I say this cause there's no port big enough on the manifold for a b35 purge valve.Comment
I am using a universal parts store rubber adapter for my purge valve. Had to use another one for the throttle body vacuum port to the charcoal canister. What diagram are you looking for? The whole harness or just a c101?sigpic<< wreckedComment
It's the same as the m20 harness I believe. What year harness do you have?sigpic<< wreckedComment
I have an extra b35 harness lying around if anyone needs it for cheap... PM pleasesigpic
Streetable poly mounts, trans mounts are here!
http://www.r3vlimited.com/board/show...ght=streetable
'94 318i
'07 335i
'11 X5
'89 325ic m30b35Comment
