trying to get my drive shaft up into place Im using a gerag 260/6 with a 87 325e driveshaft. I cant get the center bearing to push up into place and its putting a extreme amount of pressure on the guibo and the drive shaft isnt even in place. So what should I do to get it in place? Im using qbang motor mounts.
Another driveshaft question...
Tags: None
It seems you need cut the drive shaft a 1" or more?Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
DSC04926 by Raul Salinas, on Flickr
DSC03413 by Raul Salinas, on Flickr
Yea it seems like the drive shaft needs to be 1 inch shorter. Red I'm doin what your dying and it isn working.
I had to cut my drive shaft at least 2.5".Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Why? Everyone says that large flange drive shafts bolt right up. Which drive shaft did you use? I really don't want to shorten it that's gonna cost a lot to get cut and balanced
I used a 1987 325e big flange.Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
