E30B35 swap done! Running a bit hot
  • The München Monster
    • Dec 2012
    • 150
    Hey guys, after 3 days my m30 swap is done, man how cool is that. Used an E24 gearbox 4 speed getrag 262 with an m30b35 from an unknown donor car. Here's a few pics.
    A few visitors^
    Spent 4 hours getting it on the mounts
    Second time this shit happened
    Dat clearance
    Wiring takes us into day 3
    Starts up first time
    Final pic
    What a cool experience. Anyways guys yeah the cooling system was bled but it started overheating quite a bit, even went into the red. I know having no fan really hurts cooling but I think the heat was due to air in the system? Any ideas?
    Celebrating 30 years.
    1986 E30 Coupe, assembled in Munich, West Germany, 7/7/86. M10 5 Speed cruisin' through time and space
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    M30's are a bitch the bleed. What rad are you running? You really do need a 16 inch spal fan. I've never seen a m30 swap done with the early model tank.
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
      • Dec 2012
      • 150
      Dont know which radiator cause its from a local shop. Pretty big and flat though, maybe only an inch wide at the mid section, and yeah getting a 16 inch fan today, thinking of putting it in front of the radiator due to the fact thats the only way i can attach it, or is that counter productive as it may block a bit of air going into the radiator when moving?
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        In front is fine. Do your self a favor and put a mishimoto in you'll thank me later. That or a e28 535 rad
        • jim325
          • 228
          that looks like an e28 radiator, all but old and dirty as hell. I'd get a good fan, not a $30 fan that you hastily bought either, a good one. Like a spal or whatever else is actually good. Could use that radiator just clean the fins out and make sure the radiator isint plugged up at all. I got a new e28 535i radiator a while ago along with my 16" spal and it cools perfectl, 95+ degree temps.
          89 325i: 86 535i motor+trans, JE forged pistons, MLS head gasket, ARP head studs, Comp turbo, GoodNTight b34 turbo manifold, e30.de motor mounts, AKG 75D engine/trans mounts, custom 3" exhaust, intercooler, MS2PNP, Megan Racing Coilovers.
          • kamotors
            • Nov 2007
            • 7102
            lift your coolant res. tank like a a foot above the motor and while holding it up open the bleed screw(car doesn't need to be running). start filling as you hold the tank up in the air , it will push the air out of the system. worked for me on my M30.
            if that fails make sure your thermostat inst in backwards( what I did on accident)
            7speedshop.com
            • glnr13
              • 1334
              if you're going into the red really quickly after warm up i'd suspect thermo is in backwards. I did the same as kamotors and installed it backwards the first time.
              For bleeding, which i've done a few times on my m30, I followed a trick from the e28 boards... works perfectly every time and can be done totally cold.
              1. remove the overlow hose at the overflow tank. (that's the little one from the radiator to the overflow.
              2. connect another hose the same size to the overflow tank to the same place you just made the disconnection.
              3. Hold the overflow hose up in the air, it should be coming from the radiator to your hand in the air.
              4. Blow into the hose connected to the overflow until no more bubbles come out of the hose in the air.
              You shouldn't even need to use the bleeder valve. You can to test it but I'm more than positive my above mentioned technique will push out 95% of the bubbles.
              You really need to get that fan in. Cheap or not, doesn't matter IMO, just get one on there. The m30 won't survive more than 10 mins in traffic without a fan.
                • Dec 2012
                • 150
                Yeah we held the tank up and used the bleeder valve and what not the first time, second time we put the car on an incline and got some more out but i could hardly make it 5 mins up the road without it going into the red. I dont think it was backwards because it was steaming when i pulled over :/
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  Did you do any work on that motor? Do you know the condition? could be a head gasket if its over heating that quick. Check your thermostat and get a good spal fan first. I
                  • kamotors
                    • Nov 2007
                    • 7102
                    even with the thermostat in backwards it will release coolant and steam i went like 2 wees thinking that m30s just run really hot.
                    remove the 19mm plug thats on the other side if the thermostat all while holding up the res. tank, sometimes air gets stuck back there.
                    7speedshop.com
                      • Dec 2012
                      • 150
                      Replaced thermostat and tried bleeding kamotors way, temp held a little under halfway for 20 mins, still warms up more when I stop of course but the fan I got should be going in soon
                      • lukeADE335i
                        • Apr 2013
                        • 1389
                        Once you get it sorted you should have zero overheating issues.
                        My car runs a new behr e28 535i radiator with a 16 inch pusher fan from an e32 and a 71 degree thermostat. On the cruise the gauge sits on around a 3rd, and at half in traffic, even on 110F days.
                        My e30: OEM+ with M30B35
                          • Dec 2012
                          • 150
                          Hopefully mine runs that cold. I live in a place where it only gets up to like 80 degrees f haha. And on top of that it's winter here. Luckily. Yeah hopefully the fan is effective, gonna have to do some wiring to a switch in the cabin for it to work I think
                          • lukeADE335i
                            • Apr 2013
                            • 1389
                            Just noticed you're in New Zealand - with only 27 degrees in summer are you on the South Island? (I'm in Australia so we can talk celsius! :) )
                            • Mr. Burns
                              • Aug 2011
                              • 3516
                              a little off topic, but you managed to keep you battery up front and not relocate to trunk with no clearance issues?????
                              Originally posted by flyboyx
                              i have watched my dog lick himself off a few times
