M30 engine mount plans
  • jack m
    • Aug 2014
    • 2
    So I'm after the plans for the e30-m30 engine mounts. I'm aware there are different positions for them. I'm welder by trade so, I'm happy to fab them up myself and save a few dollars. Any leads would be amazing. Thank you
  • Ether-D
    • Sep 2011
    • 2838
    Is it a b34 or b35? The passenger mount will differ between the two.
    Also, I found no plans with a decent amount of searching when I made mine, so I just hung the motor in there and got it where I wanted it and tacked some up. I did the trans crossmember first to hold the motor where I wanted it fore to aft.
    Good luck and welcome to the forum.
    edit: I reckon it'll be the driver side mount that differs for you down there in upside-down land.
    Originally posted by Andy.B
    I was born on 3/25…
    • jack m
      • Aug 2014
      • 2
      Yeah okay. It's in the car I'm about to buy, 99% sure it's b35. And yeah it might even be worth just buying some and I'm keen to get the engine in. And the welder is at work with the car at home which makes it hard hah. But thanks for the advice :)
      • Doughnut
        • Oct 2007
        • 869
        I made plates for the block and rubber mounts first then hung the motor in position where I tack welded supports on place. its a bit tricky getting around the steering shaft, and I replaced the rubber donut coupling with a steel one to prevent melting, also if your using the original m30 exhaust manifold you need to modify to clear the steering shaft
        Welcome and good luck!
        ///Monstrosity. (OO≡≡[][]≡≡OO)
        Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
        • lukeADE335i
          • Apr 2013
          • 1384
          If you decide not to make your own mounts -
          I'm running e30.de mounts in my swap. Engine bolts right in & in position 3 the e34 exhaust manifolds work fine (I did get the exhaust flange rotated 90 degrees on the front exhaust manifold for extra clearance to the steering shaft).
          The Garagistic mounts are an interesting newer choice that might allow you to use headers. Not sure if anyone with a RHD has given them a go yet to see how the engine fits with them.
          My e30: OEM+ with M30B35
          • Doughnut
            • Oct 2007
            • 869
            Originally posted by lukeADE335i
            I did get the exhaust flange rotated 90 degrees on the front exhaust manifold for extra clearance to the steering shaft.
            This.
            did you keep the original rubber coupling?
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              Also I've seen a lot of people install these motors without reinforcing their subframes. I HIGHLY recommend doing this or your Frame over time will bend and twist from the added weight and power
              1991 318i 4dr slick top
              Mtech 2 turbo restoration
              • lukeADE335i
                • Apr 2013
                • 1384
                Originally posted by Doughnut
                This.
                No swapped it for an aluminium one.
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  I haven't read this or heard of this?
                  i'm not doubting this claim, however it's never been a hot issue since I read it here.
                  engine is about 60ish lbs heavier?
                  Originally posted by flyboyx
                  i have watched my dog lick himself off a few times
                  • F34R
                    sLaughter
                    • 12376
                    Sorry...but
                    OP if you need mounts, I have a jig for m30b35 I have a set already to ship at a moments notice.
                    Instagram: @BWeissLeather
                    Current cars:
                    ~ '87 325 M30B35 swap
                    ~ '87 535
                    ~ 01 540 Msport 6spd
                    ~ '06 X5 4.8is
                    • Ether-D
                      • Sep 2011
                      • 2838
                      I also hadn't heard of this being a problem. If an m30 weighs 60lbs more than an m20, and I'll be adding a 40lb supercharger, I'll have at least 100lbs more up there.
                      ThatoneeuroE30, would you mind posting up some pics of your reinforcements? Where do they go?
                      I was born on 3/25…
                      • Mr. Burns
                        • Aug 2011
                        • 3516
                        ahhh, makes more sense if you're adding SC/extra pulley's plumbing etc etc.
                        yet for the 'run of the mill' M30 swap, this isn't necessary...the only thing that's reinforced on my e30 is the rear subframe as these are a known weakness.
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          Originally posted by F34R
                          Sorry...but
                          What? Its not going to twist the frame its self that would be neerly impposible it will tweek the mounting spots as thats just a sheet of thin metal.
                          its to protect the mounting points from bending down with the added pressure from the new motor
                          these
                          Garagistic is your trusted source for high-quality BMW performance parts, specializing in E30, E36, E46, and more. Discover custom-engineered components, from suspension upgrades to drivetrain solutions, designed to enhance your BMW's performance. Shop now for fast shipping, expert support, and unparalleled quality.
                          • F34R
                            sLaughter
                            • 12376
                            I checked mine this summer, solid mounts and tons of burnout a, nothing was bent or twisted on the subframe. Now I'm not saying a plate welded in is a bad idea...I plan on doing that myself. Just saying it is not needed. People need to stop thinking the m30 is so heavy, because it is not.
                            Current cars:
                            ~ '87 535
                            ~ '06 X5 4.8is
                            • Van Westervelt
                              • 9365
                              The subframes crack and tear under normal use, even with an m42. You are best to at least box in the mount flange. I do it on all cars I have the subframe out of, despite the engine.
