Cross posting this from my build thread:
As you can see, I got the head pulled apart. First off, there was a lot of oil/coolant mixture in cylinders 3, 4 & 5. I couldn't tell if it is was from me pulling head or not, but it looked well mixed. However, I drained the oil just before and other than looking dirty, it had no coolant in it.
There was a lot of corrosion though and general nastiness as you can see. This is only the second time I pulled a head off an engine and the first time was my wife's MKIV Jetta to do a head gasket. It did not look as bad as this one.
Anyone have any insights and what I am looking at? The compression test numbers were in the 90s on the middle 4 and 150 on the outer ones. The leak-down test had similar results, but the air sounded like it was rushing out the exhaust valves. Raul's friend chatted with me and he said it is common for the middle of the head's exhaust valves to get hot and stop sealing. I will eventually test the sealing of the valves physically by pouring gas in each of the closed combustion chambers. I will also attempt to see how warped the head is with a straight edge and a feeler gauge.
Thoughts? Comments?
Edit: Oh, the cross hatching on the cylinder walls are in great shape. Pistons are in good shape too from what I can tell. I will probably pull the pan and take a look at the underside of the motor. But first, I will have to change one position of the mounting points on my stand. Cause I am a retard.
