TPS question
  • frankie591
    • Feb 2012
    • 545
    TPS question
    Simple question I hope.
    M30b35 running on m20b25 harness, which tps should I use? M30 manual tps or m20 tps? I can't find a straight answer, the link below says that the 2 tps's function backwards and are not interchangeable.
    What one should I use?
  • Doughnut
    • Oct 2007
    • 869
    Use the TPS that matches with the ecu.
    Plugs may be different so a simple cut and solder is in order.
    ///Monstrosity. (OO≡≡[][]≡≡OO)
    Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
    • lukeADE335i
      • Apr 2013
      • 1386
      I run the M30 manual TPS with my M20 loom. Plug & Play.
      My e30: OEM+ with M30B35
      • kusserwagon
        • Dec 2012
        • 43
        I am swapping in m30b35 and the tps has a different plug On it than my m20 harness has. Should I use the m30 tps and solder the m30 style connection onto my m20 harness. I've read that just swapping the m20 tps onto the m30 works fine.
        • glnr13
          • 1334
          swap the TPS. Put the m20 TPS on the m30 throttle body since you are using the m20 harness.
          • frankie591
            • Feb 2012
            • 545
            So far 2 for m30 tps, 1 for m20 tps. Hopefully somebody can definitively answer this as I was unable to find a 100% clear answer.
            • CorvallisBMW
              Long Schlong Longhammer
              • 13039
              I used the m30 tps with the m20 harness and it plugged right in
              • Hooffenstein HD
                • Nov 2012
                • 1388
                There must be two M30 TPS. The one on my 1993 B35 auto has a round plug.
                • frankie591
                  • Feb 2012
                  • 545
                  m30 auto is a round plug, variable resistance tps. manual is a 3 pin on-off style tps.
                  • CorvallisBMW
                    • 13039
                    ^both correct. You cannot use a round-plug, automatic tps with any type of manual transmission or harness.
                    • Mr. Burns
                      • Aug 2011
                      • 3516
                      bumping this up.
                      I'm now facing the same issue.
                      I've now sourced that my TPS might be faulty...I do not get a constant ohm reading when doing the WOT test, and it's inconsistent when feathering off the throttle (according to readings)
                      either way, I will be ordering a new TPS as the one I have is likely just defective.
                      I'm running a M20 harness with a M30b35 engine.
                      I removed the flyby wire system/throttle body in favor of an older e32 735 throttle body that had the same fit and accessibility to fit the square 3 pin TPS plug.
                      the part numbers are confusing.
                      the TPS that I CURRENTLY have is part number: 0 280 120 321
                      I dig a little more, and BAV auto shows part number for MANUAL ONLY m30b35's as 0 280 120 302
                      so with everything said...are we still in accordance, that, the TPS sensor part number SHOULD match the wiring harness used, (in my case m20b25) but with a 179 m30 ECU (sssquid chipped)
                      this will have no ill effect on WOT activation- and full functionality?
                      I'm sorry for the many questions-
                      these sensors aren't cheap and I want to order the right one.
                      thx
                      Originally posted by flyboyx
                      i have watched my dog lick himself off a few times
                      • Red88
                        • Nov 2008
                        • 1161
                        Try putting the m20 tps on an m30 and you will quickly find out that they are not the same part. Effectively the m20 works clockwise and the m30 works counterclockwise
                        Have you made a purchase from www.blunttech.com recently?
                        sigpic<< wrecked
                        • Mr. Burns
                          • Aug 2011
                          • 3516
                          If using a m20 harness with the m30, the...the harness should match the tps no?
                          The only m30 tps's I found where the round 6 pin plug found on automatics.
                          Which is why I went full m20 harness and tps
                          • Mr. Burns
                            • Aug 2011
                            • 3516
                            Countless people have used an m20 harness with the m20 tps (bosch p/n ending in 321)
                            Are you saying the m30 manual tps sensor is needed?
                            • Red88
                              • Nov 2008
                              • 1161
                              Yes, you have to use a manual tps (i think). I found out the hard way that the m20 tps works in the opposite direction than the m30 tps. Internally they are a mirror image of each other
                              I'm using a harness from an automatic 735i, I had to cut the 6-8 pin round plug off of the harness, and solder a three pin plug to the three wires that are the same color as the stock m20 tps plug. Other than that I had to do no other wiring. I did use the entire throttle from a manual car, but my setup is not like a lot of others
                              sigpic<< wrecked
