g260 question
  • kusserwagon
    • Dec 2012
    • 43
    g260 question
    Ok just want to clarify,
    I am using a g260 in my m30b35 swap. (it is an m30 g260) do I use the shift linkage that came with the trans? Or the one from my m20 motor g240? I remember reading somewhere that I need the e30 linkage but can't find it again. Thanks.
  • Self Made
    • Jan 2015
    • 153
    Based solely on the research I've done I think you're right.
    You can use a linkage from an M30 car but you'd have to modify it.
    Modifying the linkage isn't very hard, just cut, measure, cut, weld. Engine and tranny should be installed for accurate measurements.
    • Mr. Burns
      • Aug 2011
      • 3516
      I *believe* you can leave the e30 M20 linkage in there.
      I'm really hoping so, as it's one of the "not sure's..." about my swap I'm currently building aswell.
      there's been so many different answers, and so many different variables
      Originally posted by flyboyx
      i have watched my dog lick himself off a few times
      • frankie591
        • Feb 2012
        • 545
        I used my stock m20 shift linkage with my swap. (m30 g260). I guess it will vary slightly depending on where your mounts position the engine but it should be close enough to center the shifter pretty well.
        • hotdish
          • Aug 2014
          • 20
          I used the garagistic mounts on my car (position ~2.5 IIRC) with the late cast aluminum e30 325i shifter linkage and it lined up just about perfectly.
          Originally posted by Japandrew73
          I'm not going to be "cutting up" the subframe, I'm going to be notching it
          '92 335ic Alpinweiss II/Indigo
          '79 323i Arktisblau Euro
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            When I did my m30 swap I shortened the shifting arm and linkage. I used m30 version of both.
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • kusserwagon
              • Dec 2012
              • 43
              Were your garagistic bolt holes larger than the bolts that mount them to the block. I mean the bolts have a lot of wiggle room on the mounts. Cause I just got my garagistic mounts and the holes are huge.
              • kusserwagon
                • Dec 2012
                • 43
                Another question, I have read that you can swap the trans output flange from the m20 trans onto the g260 so you can use your original drive shaft. However today i went to do that and the teeth were smaller on the m20 flange so I couldn't swap it. Is there a certain m20 trans that has the correct teething?
                • lukeADE335i
                  • Apr 2013
                  • 1389
                  The small output flange needs to be from an M20 Getrag 260.
                  I'd always wondered whether the G240 flange would fit - thanks for answering the question!
                  My e30: OEM+ with M30B35
                  • frankie591
                    • Feb 2012
                    • 545
                    I swapped my m20 g260 flange onto my m30 g260 transmission the spline is the same. However the m20 flange I used was a lot shallower than the m30 flange so the pilot/tailshaft that fits into the driveshaft was too long. I had to cut the stub on the output shaft down about 1" and file the OD down until it fit into the driveshaft.
                    • hotdish
                      • Aug 2014
                      • 20
                      On my car, I just drilled a hold in the end of my 323i driveshaft so the output shaft would fit into it.
                      • evandael
                        • Oct 2009
                        • 2881
                        Have you had any concerns about breakage? I'm trying to decide between an E34/E30 hybrid driveshaft or swapping output flanges and cutting output shaft/maybe drilling the driveshaft.
                        • lukeADE335i
                          • Apr 2013
                          • 1389
                          I've been running a Getrag 240 behind my M30B35 for 3 years now. It hasn't broken. Running the small output flange on the Getrag 260 won't cause you any issues.
                          • evandael
                            • Oct 2009
                            • 2881
                            well i'm just concerned about drilling a hole in the d/s. i guess i could just cut down the output shaft.
                            • lukeADE335i
                              • Apr 2013
                              • 1389
                              It may depend of which driveshaft you have as to whether you have to mod it or not - a mate of mine who did this bolted a 323i driveshaft straight up.
