2JZ-GTE Swap/fuel pump Question
  • CarMetic
    • Aug 2014
    • 81
    To any of you with experience in this particular swap, or maybe experience dealing with the same issue:
    I am having a problem getting power to the fuel pump. Fuel pump is new and works. I get power to the ECU and Power to the pump from the ECU. However I do not get power at the fuse for the fuel pump and thus no power actually going to the fuel pump. All of the fuses were replaced and everything else seems to be functioning normally.
    any ideas or solutions out there??
    its a 96 2JZ-GTE with single turbo conversion, stock intake mani - if that matters and I'm running a custom harness from Tweak'd Performance (no bmw fuel pump relay on the harness, which is how they say they build them)
    any insight would be greatly appreciated!
    1990 325is 2JZGTE Swap
    1989 325ix Coupe
    1988 325is Coupe
    1988 325i Euro Vert
