All of you turbo m30 guys, what have you guys done for the oil feed? I kind of jumped the gun and tapped the oil filter housing cap without really researching and now I realize i may have messed up. Will this have a high enough psi? Do i need a different oil filter for clearance of the feed? Anything helps.
M30 turbo oil feed question
Tags: None -
Some people (inlcuding kamotors) succesfully tapped their filter caps and had no issues. Personally I drilled+tapped a blank boss that's lower down on the housing and used that.
From the build thread in my sig: http://www.r3vlimited.com/board/show...&postcount=181
