oil leak!.. please help.
  • s52e368
    • 539
    so i had a nasty oil leak, did some searching and found that the oil pan gasket is to blame a lot of times.
    so i did a new gasket install and seafoam cleaner etc... (wiped the motor down to watch for leaks)
    BUT come to found find out i still have a leak. its on the pass side of the engine. i dont think its the control valve, because the leak looks like it is further toward the front behind the rotater cap. and looks to be higher up than the control valve also.
    any ideas ?
    ill post a pic in a few minutes.
