This is something that I have always thought about but never physically have done. I have installed engines, Ive "swapped" from eta to m20b25, and have done a basic plug n play vw swap (ce2 mk2 from diesel to obd2 aba).
One thing that I have always wanted to kind of know is how people swap a not so plug n play engine.. or possibly non model related engines. Lets make a hypothetical scenario below.
Lets say, a 2jz into an e30 (no I am not considering this at all).
Now, the only options that I know of would be to 1). use the e30 full harness and in essence splice the pigtails of the 2jz engine components into the e30 engine harness (still utilizing full e30 fusebox, body harness etc). Issues I see here would be afm-> maf, or if a 2jz sensor had more wires then what an e30 had (such as a 4 wire o2 but having to wire in a 5 wire heated).
The other option I see would be to run a full wiring harness for the 2j along with a 2j fusebox. Then, anything that isn't engine related (such as lights, dash, radio, etc) would be cut off the 2j harness and your original e30 harness spliced essentially into a 2jz fusebox.
Besides those two, or possibly a Painlesswiring system (of which I have never researched), does it seem I have the basic jist down?
I just don't know anyone who has done wiring a swap before, and everything I read is usually just consisted of buying a 500$ PNP harness. Thanks!
