M30b35 power steering pulley?
  • Streichholzschächtelchen
    • Jan 2009
    • 1670
    Going to be using an m20 power steering pump on an m30b35 and i was wondering if it mattered wether i use a b34 or b35 pulley? I have an e28's b34 pulley tucked in the trunk of a car at a local part yard. Same offset I'm assuming.
    Jah bless! :pimp:
  • nighthawk
    • Oct 2013
    • 70
    Not sure on the positioning of the M20 pump, but you should note that the b34 vs b35 belts are different lengths, which probably means that the pulleys are different sizes.
    10 X 888 M30B34
    10 x 865 M30B35
      • Jan 2009
      • 1670
      Well i pulled a b35 and got the pulley off it. We'll see, it had an identical looking pump to my stocker.
      Jah bless! :pimp:
      • lukeADE335i
        • Apr 2013
        • 1386
        Pretty sure the pumps are the same just with different pulleys, so you should be fine.
        The M10 pump also bolts to the M30 mount - I'm running one of these on my car. They run at lower pressure, giving less assistance and meatier steering.
        My e30: OEM+ with M30B35
