M30 sliding forward under hard brake
  • Ryan335
    • Jul 2015
    • 45
    I'm using garagistic swap mounts for an 89' b35 in an 87' e30 chassis. Revshift 95a mount on the drivers side, and custom 98a on the header side.
    At best I get a 1/4 inch of clearance between the radiator and the distributor cover, then after heavy braking I'm about a sheet of paper from touching.
    This happened once before and I pushed the engine back and cranked down the mounts. Now its back. I feel like if I hit something the engine would just keep going...
    Solutions?
    - The swap mounts have oversized holes - make spacers to fill the voids so it can't slip forward
    - Fab one of those bushings that hang off the block and push against the subframe
    - Yer doing something wrong
  • e30m3s54turbo
    • Jun 2010
    • 3277
    On one of my big swaps I have adjustable steel mounts similar to Hartge H35 and H35-24. I had no issue sliding forward. I did add metal to between the gaps to prevent any movement.
    • lukeADE335i
      • Apr 2013
      • 1386
      Could be the oversize holes. How big are the washers under the urethane mount nut? A bigger washer might give more grip on the arm if you can't find a shim to fill the gap?
      Don't worry about whether the engine will touch the radiator if you hit something - it definitely will! The radiators are pretty tough though, I rear ended someone in mine, and with the radiator severely bent it still held coolant so I could get home.
      Great looking swap you have there by the way! Well done.
      My e30: OEM+ with M30B35
      • Ryan335
        • Jul 2015
        • 45
        Impressive! lol. And thank you I appreciate it, turned out to be quite the project.
        The rev shift mounts are somewhere around 40mm, the mount I put together uses a 60mm washer so there's a good amount of surface area there. I think by design its prone to slip.
        I think this will be the ticket. I'm gonna cut down some steel tube to sleeve the bolts to the appropriate size.
        Additionally I'm going to fab a mount to hit the sub frame in the event of a sudden stop. The M20b27 had one on the lower pan/bell housing piece and it rested between the sway bar and subframe. Part 14/15 in this image.
        [IMG][/IMG]
