Misfire? *VID INSIDE* M30b35 swapped E30.
  • Mr. Burns
    • Aug 2011
    • 3516
    I think I'm detecting a bit of a misfire at idle, and as I rev the car.
    where would I start in efforts to smooth this out?
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • Jb325is
    • 2137
    Pull the wires off the plugs one by one with engine running to see which cylinder(s) is affected. Are you running b35 harness with the injector box? Make sure on of the injector plugs didn't back off. If you are able to isolate the misfire to one cylinder, and there's nothing obvious wrong, do a compression test. My m30 blew a headgasket between cylinders, and only indication was a misfire.
    - '88 m54 coupe
    <3
    • Mr. Burns
      • Aug 2011
      • 3516
      I'm not burning any coolant, and the engine runs ncie and cool (rare for a M30 in E30)
      I'm running a b25 harness.
      i'll pull the plugs as you said and try to isolate the cylinder.
      I've been noticing there's a definate "surge" when cruising at times too, where it feels as tho the engine is pulling back slightly, then clears up.
      I don't drive the car enough to really get a good feel for it tho.
      • lukeADE335i
        • Apr 2013
        • 1389
        I was going to point out that the M30B35 has a pretty lumpy idle, but that's definitely a miss - you can hear it higher in the revs too.
        Hopefully just a crook spark plug or lead. Are the distributor cap and rotor fairly new? The ignition system is definitely the place to start.
        My e30: OEM+ with M30B35
