ANOTHER--help with wire identify *pics*
  • Slick92GS-R
    • Apr 2005
    • 662
    help on my other was great!! -
    this is a '88 'i' harness & motor into 87 ETA--
    on the DRIVER's side, under the throttle body there is a plug (yellow circles) that is joined on the harness to two others. i need to know to what does the green circled plug connect to? it is the longest wire on that section of the harness
    does the plug in the blue circle connect to the o2 sensor ?..
    is there a use for the green circled plug in my application ? i see nowhere to connect that circle plug
    --Hayden--
    '87 325 coupe- Trak Rat
    '93 318is- 4cyl's of fury
    '92 Integra GS-R--yeah, its fast..
    www.G2IC.com
  • mcgrath
    • May 2004
    • 445
    First pic. The plug goes to the idle control valve. On the later motronics they got an updated ICV which is right there at the throttle body. It uses a 3 pin plug just like that.
    Second pic. The blue circled plug I am not sure about. I will look at my car when I get back home from work around 6:30.
    The green circled plug is for your O2 sensor.
    • mcgrath
      • May 2004
      • 445
      So what are you doing? A full motronic 1.0~1.3 swap. If so, welcome to the club. :)
      • rs4pro3
        • 5808
        blue circle is your 3-wire o2 sensor plug
        Green circle is your new 4-wire o2 sensor plug
        Red circle is a ground
        85 325e 2.7 ITB'd stroker
        • Slick92GS-R
          • Apr 2005
          • 662
          man, i luv this !!1 great info -- yeah.. its a '87 ETA chassis that i have. i'm swapping an 89 i motor, dme & harness -- it has like 41000 miles on this new motor..
          --Hayden--
          www.G2IC.com
