Originally posted by Shangsta
View Post
Honda K24 swap interest?
Originally posted by KMiata View PostRegarding N/A engine builds - a stock K24A2 will get you around 220whp and can safely rev to 8200 RPM on track. Skip the K20 for N/A, there is no comparison over the larger K24. My mild 12.5:1 K24 build in my Miata (251whp) makes peak torque around 2600 RPM and it carries flat to 8500 RPM. No comparison over a peaky K20 or F20C.
I have the option of buying a E36 ZF 5 speed for 300$, guy acid dipped it and had it refreshed. It was going in a 600hp+ turbo m50 car. Should I buy it from him in preparation for the honda swap? Im planning on going NA k24 then adding boost in the future. Is this trans going to handle the power? And I know it can be done but ive had trouble finding a good guide on swapping one of these into a E30, does anyone have a good guide?91' 318is 90' 325is
Originally posted by SonnyBuy the E30s, they ain't gonna last long
E30 can make you, E30 can break you
Originally posted by Jaker View PostE36 ZF is good for 600+ whp and 350-400 ft/lbs. It's when you get into the 500+ wheel torque numbers that the BMW I6 is quite capable of when properly built that you need to start worrying about the ZF.91' 318is 90' 325is
Originally posted by jwal View PostHow many miles on the ZF? I think 300 is a decent price for one around 150k miles are so.
What does refreshed mean in this context? 5th gear spring and seals?91' 318is 90' 325is
Nice
I found a few threads on this related subject but long story short, which is the lightest engine swap for an 1984 318i?
Seriously, from what I read today....N52?
The M30 adds 40lbs? Obviously with a different transmission, yet more weigh is added.
Is the M52 really lighter than an S52 enough so that the M52 swap is a bit more desirable?
How does the K24 compare by comparison in terms of weight to the M30, N52, and M52?
I am sure this has been discussed, so if someone has a link, please share.
All I found was this:
Originally posted by Javier h View PostIs the M52 really lighter than an S52 enough so that the M52 swap is a bit more desirable?
The iron block M52 single Vanos is marginally lighter (maybe 5 lbs) than the S52, but the aluminum block single Vanos M52 from the 97-98 Z3 is 50lbs lighter (as verified by me personally on a scale).
