Chassis / brake upgrade to E30 M30 swap
  • MiWision
    • Mar 2018
    • 17
    We have an E30 320 with M30B35. The car has a 318is front axle with 51mm suspension legs and a rear axle with disc brakes.
    Original 320 brakes are mounted in front.
    What upgrades on chassis and brakes have you done on your E30 M30 swap?
  • Anthony B
    • Nov 2012
    • 308
    Front strut brace(is pretty s@#t quality so does nothing)
    Massive brakes street kit
    Braided lines, street/track pads
    Ie 24mm sway upfront 19mm white line rear
    450lb front springs with Koni sports & 650lb rears with GAZ dampers
    Car is pretty neutral balance wise, on the track last weekend I got to really test the brakes/suspension. Brakes where fantastic no really fad issues/ suspension too firm in the rear(sway bar too still)
    • wannaBMthree
      • Apr 2007
      • 601
      M3 offset CAB's I highly recommend
      Poly all around
      • lukeADE335i
        • Apr 2013
        • 1385
        Chassis
        Eibach prokit springs and Bilstein B8 shocks + poly bushes for control arms and rear subframe.
        Brakes
        Higher temp brake pads and blank brembo discs. For a street car the stock brakes are adequate.
        My e30: OEM+ with M30B35
        • kronus
          • Apr 2008
          • 13029
          if your 320 came with a small-case diff it might not be a shit idea to upgrade to a medium case.
          stock brakes are fine with good pads in them.
          what are you building this car for?
          cars beep boop
          • MiWision
            • Mar 2018
            • 17
            At present, the car has the small case differential with 3.64 gear and a M10 Getrag 240 gearbox.
            The car comes to 99 percent to be used on the street but we drive the most on a curvy road.
            I appreciate the advice you've given so far, helping us choose the right parts for the car.
            • lukeADE335i
              • Apr 2013
              • 1385
              Budget for a LSD diff - definitely worth it with the torque at hand.
              I started out with an open diff, and the car was a bit of a handful in the wet - once I swapped to LSD it has driven like a factory one, wet or dry.
