I was thinking of getting a turbo from TCD, non-intercooled and running it in my M30 (E32). I was told by todd (who is very helpful by the way) that with what i'm running, which is relatively a bone stock setup, with exception to the LW flywheel, that with a non-intercooled setup, 30lb injectors, I could probably pull about 300rwhp with a 8psi boost.
The engine is very healthy, all maintenance parts have been replaced with stock parts. I have no cooling issues. It is running perfect.
He said clearance issues would not be a problem. So what do you guys think?
Think it's worth a go? Do you think these numbers are relatively true? What max psi can I run without blowing a head gasket?
