this is were my project begins.
1986 BMW 325 2 DOOR (M30 SWAP)
1991 535i M30 Engine (3.5l inline 6)
• Turner Motorsport Jim Conforti Performance Engine Chip ~235hp at the crank
• Bosch Design II (4 nozzle) 19lb/hr Injectors
• New Water pump, Thermostat, Spark Plugs
• Ireland Engineering Urethane Race Motor Mounts
• e30.de M30 -> E30 Motor Mount Brackets Engine Position III
• Fully Custom Dual 2.25” Exhaust with High Flow Magnaflow Catalytic Converter and Stromung e30 M3 Rear Muffler Section (Very European Sound!!)
• Brand New E28 535i Radiator
• Zirgo 16” 3600cfm Electric Fan
Drivetrain
1991 535i Getrag 260/5 transmission (5 speed) 190k mi
• JBRacing Lightweight Flywheel
• SPEC Stage 3 Clutch Kit
• UUC Urethane Racing Transmission Mounts
• New Driveshaft from Driveline Services of Portland
• Understeer.com Short Shift Kit
Suspension
• Ground Control Coilovers
o Spring Rates: 425F/450R
• Koni Sport Adjustable Shocks
• Ireland Engineering Race Fully Adjustable Front Camber Plates
• Ireland Engineering 25mm Front Sway Bar and Mounts link links bushings
• Ireland Engineering 22mm Rear Sway Bar and Mounts link mounts bushings
• Ireland Engineering Urethane Race Rear Subframe Mounts
• Ground Control Rear Shock Mount Reinforcement
• Urethane Rear Trailing Arm Bushings
• E30 M3 Offset Front Control Arm Bushings
• New Control arms and Tie Rods
• H&R Hubcentric 4x100 15mm Spacers
• Genuine SSR GT1 17x7” Wheels (4x100) 17lbs each Lightweight Race Wheels
• Tires are Bravus Bavarium in the rear and Bridgestone RE750 Fronts (215/40/17)
Brakes
• Brembo Rotors Front Rear
• Stainless Steel Braided Brake Lines
• ATE Racing Super Blue Brake Fluid
• Pagid Front and Rear Performance Brake Pads
Misc
• Prolumen HID Kit 6000k H1 Bulb
• European Ellipsoid “Smiley” Projector Headlights
• Viper Alarm
• Kenwood 9102 Amp (1700 Watt)
• Sony 1502 Amp (760 Watt)
• 1991 535i Stock Speakers
• Sony CD Deck
• Alpine Type R 10” Sub in Custom Ski Pass Enclosure
• Schucks Auto Supply Leatherette Racing Seat in Driver’s Side
• Tucked Front and Rear Bumpers (Front is Color Matched to Body
Drivetrain
Suspension
Brakes
Misc
• Viper Alarm
• Sony CD Deck
