holy shit dude, i had no idea, i fucking love your car!
M30 E30 official roll call thread
This is a sticky topic.
1984 318i chassis
91 m30b35 out of a 735
179 ecu, 535i b35 harness
91 g260/6 out of a e34 535i
533 flywheel
e30 clutch master/slave
sachs e28 535i clutch kit
z3 1.9 shifter
e30 325i shifter rod/arm
b35 engine mounts from joe
e30 325i engine/tranny mounts
big guibo e30 driveshaft
e28 535i 5speed radiator
e32/e34 b35 coolant hoses
e28 535i lower radiator hose
e32/e34 b35 overflow tank (soon to switch to e30 325i tank)
89 535i automatic harness with my own adapter
magnaflow 36008 cat, custom 2 into 1 2.5" rear section with 11216Last edited by Jean; 01-22-2010, 10:15 PM.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
They look really good!Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by LowR3V'in View PostWho made those?
He also fabicates superb exhaust manifolds for turbo setups.Current:
BMW 320i 2d 2.0 m20 -88
BMW 325i Cabriolet 2.5 m50 -88
BMW 316i touring 1.6 m40 -90
BMW 320i 4d 2,2 m54 -01
i guess its about time i put mine up.
89 325i coupe
drivetrain
m30b35 from 89 e32
getrag 260/6
joefunk mounts
markd chip
ssk
stock 325 rad and driveshaft
3.73 LSD
other mods of interest
Borbet type A staggered set up (fronts 16x7.5, rears 16x9)
bilstein sports with FK 60/40 springs (2.3 front, 1.5 rear)
eibach adjustable sways
thinkin i should go MS then turbo, like to find a nice mtech II kit as well....
open to helpful suggestions
89 325i touring, Stripped and caged.
M30b35 and box from 90 e34 535i sport.
e28 flywheel (single mass) and clutch
z3 1.9 and e21 m20 shifter and rod's.
Modified 535 front half prop
3:46 lsd
Big bore TB with matched inlet manifold
gas flowed head with cat cam
Custom air induction pipe to give same surface as oem box with huge k&n cone.
custom exhaust 6-2-1 straight through
Bird's custom chip and mapping.(all m30 loom from c101 with 3 wire mod's)
e28 rad and e32 ac fan
100hp nos kit
80mm drop all round
tar-ox brakes (oem size)
Alipna 7j front and 8j rear
Alpina front lower spoiler
Mtech 1 kit inc metal bumber's
I have a howslett turbo from a 7½ ton truck and am just getting the rest together.Last edited by zaust; 02-08-2010, 06:29 AM.325i touring, 327i 2 tone tech 2, 335i tech 1 touring with nossigpic
swapped m30b35 from 1992 e32 into a '89 325i
getrag 265 transmission
z3 shifter
custom drive shaft
e34 radiator
running stock e30 coolant reservoir with a custom T splice into e32 coolant piping
635 exhaust manifold and headers
full 3" exhaust with high flow cat and magnaflow muffler
Bosch 30# injectors
IE adjustable fuel pressure reg.
Dinan chip
other non-engine related modifications
team dynamic motorsport wheels
Dunlop direzza sport z1 star spec tires
Bilstein sport
Ground Control single adjustable coil over springs
Ground Control camber/caster plates
