m30 vs m20 oil pan height.
  • King Luis
    • Sep 2004
    • 737
    so after a m30 swap, is the oil pan in the m30 lower or higher then the m20?
    and with what oilpan will you get what result?
  • E30/M30
    • 224
    I can't remember how low the M20 oil pan was but the M30 oil pan does seem vulnerabley(sp?) low with my lower than standard ride height, the plastic shit guard fits back on ok with the M30 so not that much lower i guess ?
    I keep a spare oil pan just incase though, a metal skid plate would be a good idea too.
    • MrK
      • Jan 2006
      • 709
      I believe the M30 oilpan is fractionally (read negligibly) higher than the M20 pan. Based on personal experience.
      This is your M20 on steroids:
      • ejnight
        • Apr 2007
        • 3488
        I make the M30 Skid Plates.
        http://raceskids.com/
        • E30SPDFRK
          • 5716
          I would say about an inch higher than an m20 pan. The subframe is lower than the oil pan is.
          Byron
          Leichtbau
          • Doughnut
            • Oct 2007
            • 869
            Wow, you have your engine up high, does any engine parts rub the underside of your bonnet?
            My m30 sits just alittle lower (1/2") than the steering rack.
            ///Monstrosity. (OO≡≡[][]≡≡OO)
            Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
            • LowR3V'in
              • 4209
              ^ I agree that's pretty high up there if it's higher
              then the subframe. Do you have any pics?
              Mine is about the same as stock.
