Bleeding the cooling system? Magicians, please help.
  • Funkmasta
    • May 2004
    • 7185
    Has anyone had any REAL luck bleeding the cooling system? My reservoir is the highest point in the system, but the radiator is still higher than the thermostat housing. This is a problem.
    help?
    Joe Funk -- Portland Oregon
    That Guy.
    03 X5. 3 liter obviously.
  • bmw335isturbo
    • Mar 2006
    • 218
    Hey Joe good luck with that one.
    as soon as I stat working 5-8's agean I am going to start with my car agean.
    I am going to try placeing the engine at the same level as I had it with my first 335i I think that shood fix most of it
    I will keep intouch.
    I also need to get the engine and tranny out of the 91
    E30 for the cage I can't wait until I can get some time off or reduced
    1986 335is-1988 335ist -1991 335istsigpic
    • euroshark
      • Apr 2006
      • 3491
      You could pull the radiator off of the supports and let it drop down I guess, that sorta sounds like it could work.
