Quick M30 335i Poll
  • SpunkyE30nOk
    • Jun 2006
    • 228
    Quick M30 335i Poll
    After you put your motor in did you reconnect your OBC? I want my E30 to be as close to a production 335i as possible.. I have an uncracked dash to put in and my light for my OBC is out currently. but the computer itself still works. When I do my swap i still want to keep it in working order. If you did hook up your OBC after your swap was your mpg some what accurate or wrong b/c its designed for the m20
    9
    Yes Did and it works fine
    44.44%
    4
    No I didn't b/c....
    33.33%
    3
    What is an OBC...do I even have one
    22.22%
    2
  • NomadE30
    • Mar 2007
    • 236
    well i am assuming you are going to change out the ecu's with the wiring harness. Check realoem.com to see if the OBC are different in the 535i then the 325i. I can't imagine a problem unless your making your m30 better then stock with bigger injectors and such, but i am sure it still will measure it fine
    • euroshark
      • Apr 2006
      • 3491
      It didn't need reconnecting as I recall... I plugged the new harness in at the fuse box, and it was a square plug car.
      • Mike325
        • Mar 2006
        • 3685
        Yes Joe.
        Originally posted by Kershaw
        • SpunkyE30nOk
          • Jun 2006
          • 228
          what harness did you use? modified m20 or the harness from your m30? Im going to use the harness from a 87 635csi since thats what i got the transmission from
          • Garageaholic
            Freestyle Fabricator
            • Dec 2005
            • 5204
            I didn't even bother with an OBC. I went straight to an analog clock.
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            Instagram.com/garageaholic
            Youtube.com/garageaholic
            • SpunkyE30nOk
              • Jun 2006
              • 228
              I mostly use my OBC to check my fuel range *yes my fuel guage works*, mpg highway and city
              • ldsbeaker
                • Aug 2004
                • 3098
                I like having the computer too.
                Slicktop City!
                • bumpstop335i
                  • Mar 2006
                  • 64
                  Mine does not work because i lost the loom in a flat shift.
                  Anyone have a spare OBC loom for sale?
                  • JoeMadoo
                    • 936
                    I never disconnected mine...
                    '86 E30
                    '05 E53 X5
                    '72 Firebird
                    '10 Prius
                    '03 Tundra
                    • george graves
                      • 19998
                      Originally posted by Matt-B
