So my M30 runs great for about 5 minutes. When I take it for a ride around the block i barely make it back, it starts running like shit, and i can barely go up my driveway. It's not overheating. If i try to give it more gas, it just sputters, and I think i might have heard a valve hit a piston :(, but im not sure.
Bogging Down
check ya cap and rotor...I'm having the same issue with my m20, but mine won't stay running unless i give it some gas and then it sounds like shit. I figured out today that I over torqued my ignition rotor.Comment
You sucked a bird in your afm with no air filter?sigpic340hp V8 e30 FINISHED!!!!!
Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
NEW One on the track :)
http://www.youtube.com/watch?v=K-AX5SzSLnk
Cleaning up some 911s and Jap turbos
http://www.youtube.com/watch?v=Ad79wsLdle4Comment
bird???where in this thread did he say bird haha
but if its true then i agree release the bird...let him live!!!!!!!!
good luck with your finidings...M stands for Money:hitler:Comment
Haha. It seems like the bird only gets stuck when the engine is warm. My Idle Stabilizer Valve buzzes like crazy when its on also. I'm not getting the right voltage reading from the ISV harness connector, so I think my computer might be loosin it.'86 E30
'05 E53 X5
'72 Firebird
'10 Prius
'03 TundraComment
Try cleaning the ICV. check for vacuum leaks, plugs.
fuel filter?
Is your crank angle sencor tight or loose?Comment
I cleaned the ICV.
New plugs, fuel filter.
No visible vacuum leaks either.
My sensor up front was loose, but i did tighten it and no luck.
I have a new coolant temp sensor, which i tested and it works.
The thing that bothers me is that when i test for 12 volts on the 3 wire ICV connector, there is only 9 on one side and 3 on the other. I think that is what is making the little guy buzz too.
It runs perfect when its cold, but when its warm its all i can do to drive it up my driveway.'86 E30
'05 E53 X5
'72 Firebird
'10 Prius
'03 TundraComment
weird....have you tried testing the icv valve when she's cold to see if you've got 12 volts?? or is it the same when warm....and
i forget the name of the part(sorry)...but on the throttle body isnt there a sensor that needs to be calibrated, if that come loose or out of its original position doesnt it get fucked??? or...
am i just a moron and thats the idler controll vavle ICV????M stands for Money:hitler:Comment
Kyle Sutherland
1995 BMW 540i/6: The Calypso Beast Vid 0-70ish
1987 BMW 325es: Face & Butt Lifted/M50tu Swapped*Sold*
1985 VW Scirocco: Too many mods, money pit*Sold*Comment
