m30 fucked
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    I had my car all ready to go last summer. Took it for a drive. Ran fine! Then it started leaking from the area between my tranny and engine so i immediately thought, "rear engine seal". I should have changed it when i had it out of the car in the first place, but I knew that if i didn't address it, it would have gotten worse. I rented an engine hoist and went to work. Removed the engine/tranny all by meself and changed it completely. After realizing what had caused the leak, I realized that after looking in the tranny bell housing that I put too much grease in there for the throw out bearing. Turns out that the grease inside the bellhousing was melting from the heat, liquifying, and dripping out at the engine/tranny area. Didn't even need a rear engine seal!
    But i did it becuase it had to be done. I wasn't giving up on the m30 just yet. I'm sure that a rod won't be too much harder to fix. I hope not at least.
    it could be a great opportunity to replace or even upgrade other M30 parts while it's out of the car!
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • JoeMadoo
      • 936
      Sounds good. I noticed the same thing coming out between the engine/trans and thought the same thing too, but i'm just lazier than most.
      '86 E30
      '05 E53 X5
      '72 Firebird
      '10 Prius
      '03 Tundra
      • george graves
        • 20003
        Man, sorry to hear that...
        Originally posted by Matt-B
        • JoeMadoo
          • 936
          So now that i have my block apart is there anything i can do now to beef it up for turbocharging?
          I recall having 0 oil pressure. i tried several different oil temp switches, and a vdo gauge with a good sending unit and still had no oil pressure. I also tested my pressure light and it is wired correctly. I just dont understand how there can be no oil pressure and it still ran fine. What can i do to check to see if i have a oil pressure problem while the m30 is apart?
          '86 E30
          '05 E53 X5
          '72 Firebird
          '10 Prius
          '03 Tundra
          • Garageaholic
            • Dec 2005
            • 5204
            You gonna put low comp pistons on it?
            MLS headgasket too...w/ head bolt kit
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            • JoeMadoo
              • 936
              Well I know the m30 has pretty low compression already.
              Now that i think about it having no oil pressure could kill connecting rod bearings, and mine look pretty bad.
              '86 E30
              '05 E53 X5
              '72 Firebird
              '10 Prius
              '03 Tundra
              • SpunkyE30nOk
                • Jun 2006
                • 228
                are u gonna post up pics of your motor torn down?
                • gotKRAUT
                  • Apr 2007
                  • 136
                  post some tear down pics...stat! so we can help figure this shiz out
                  Kyle Sutherland
                  1995 BMW 540i/6:
                  The Calypso Beast Vid 0-70ish
                  1987 BMW 325es: Face & Butt Lifted/M50tu Swapped*Sold*
                  1985 VW Scirocco: Too many mods, money pit*Sold*
                  • kylebes1
                    • May 2004
                    • 2804
                    m30 bottom ends don't break. Not with a mere 200k miles...
                    • JoeMadoo
                      • 936
                      Found the culprit. This is the #3 rod bearing.
                      The rest don't look to hot either.
                      So do you guys think i should have the crank grinded and get oversize bearings or not? And replace piston rings or not?
                      '86 E30
                      '05 E53 X5
                      '72 Firebird
                      '10 Prius
                      '03 Tundra
                      • T.Dot_E30
                        • Mar 2004
                        • 286
                        I think you really should get the crank re-surfaced because the bearings seem bad and im sure there must be some groves on the crank.
                        Since you need to take it all apart, it might be better to just get stuff done now.
                        • SpunkyE30nOk
                          • Jun 2006
                          • 228
                          +1....what if you use certain over sized pistons/rings will it make it a 3.6? :p or how bout a 3.8
                          • JoeMadoo
                            • 936
                            Boring and new pistons cost alot of $$$, but if I could i would in a heartbeat.
                            Anyway, I found something else that could probably add to or even be the cause of the knocking. There was a missing bolt on my cam timing gear and the other 3 were barely hand tight, so the gear was floppin around, and only god knows where the last little bolt went, i can't find it. And yea, I'm the dumb ass who didn't tighten them.
                            '86 E30
                            '05 E53 X5
                            '72 Firebird
                            '10 Prius
                            '03 Tundra
                            • triggrhaapi
                              • Feb 2007
                              • 350
                              Awwwww. Dude that sucks. Don't worry, this is a good thing. You NEEDED this rebuild anyway. Old motor, tired motor, needs revitalization. This will end up giving you a practicality that you never had before.
                              1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
                              • euroshark
                                • Apr 2006
                                • 3491
                                Doh!
