i've searched and done a lot of reading on this forum about the m30 swap in the past couple days. good stuff. my need to do this swap just go accelerated by about 6 months today because i twisted off my oil drain bolt while trying to put in thicker oil to try to get a few more months out of the m20.
long story short, i'm looking to buy an M30 within the next two weeks. i need to know what to buy and what i need to change.
1: i can keep the getrag 260 right? can i keep it in place without moving it assuming i fabricate my own engine mounts?
2: i know i can keep my stock wiring harness and just lengthen some wires, but i need the m30 ecu right?
3: can i keep my stock diff for now or should i change it, and if i need to change to the big case diff, do i need the axles too?
4: what year/model cars should i aim for? what's the best and what should be avoided. right now im looking at a 1990 735 for $500...can probably bargain down
5: is there any other serious issue i'm leaving out here? im thinking of just buying just an engine straight from a junkyard and going from there.
6: any good tutorial i could use for reference? i need one :)
thanks much for any help. i'm not totally clueless here as i've done some reading and have had my engine out before. just need some specifics cleared up.
- I say be a man and wire it all yourself, with electrical tape and man sweat. ... And solder.
