M30 troubles
  • JoeMadoo
    • 936
    M30 troubles
    This m30 is ideling rough and has no throttle response, as in hit the gas and it almost dies before it r3vs up. I need clues...
    Things i've checked:
    - Vacumm is 15 at idle.
    - I hear what sounds to be a vacuum leak around the FPR but there are no leaky hoses....
    - Wires work
    - Rotor is new, cap has slight wear but seems ok.
    - Played with the timing gear moved from tooth to tooth but still runs the same. I even checked it with a timing light.
    I NEED HELP!
    '86 E30
    '05 E53 X5
    '72 Firebird
    '10 Prius
    '03 Tundra
  • bmw335isturbo
    • Mar 2006
    • 218
    check the rubber boot really good were the idle control valve is and around where the hose clamps are.
    1986 335is-1988 335ist -1991 335istsigpic
    • mattdk318i
      • Jun 2006
      • 3953
      Fpr? And or the diaphram inside of it?
      • JoeMadoo
        • 936
        Well i figured it out... The number 4 fuel injector plug was unplugged. So the whole time i was running on 5 cylinders. I still beat a new civic si, haha.
        But now i have anther stupid problem. After merely removing the radiator and disconnecting the 2 radiator hoses (because i thought the timing was off so i had to make some room) my car overheats and there is no coolant circulation anymore... And i did fill it back up and bleed it.
        '86 E30
        '05 E53 X5
        '72 Firebird
        '10 Prius
        '03 Tundra
