Who is running what engine harness
  • SpunkyE30nOk
    • Jun 2006
    • 228
    It seems i have parts from just about every 80s Bmw there is for my swap.. Motor from an e23, trans and harness from an e24, clutch/PP from an e28, and my e30...anyway which harness is best to use for the motor? My stock harness or the harness from the e24.. the e24 was an 87 635csi w motronic 1.1. I really want to get away with cutting and splicing as little as i can b/c wiring is my worst subject as far as auto mechanics go. If you used the stock harness what did you do to hook it up. If you used a different harness how did you adapt it to the e30 fuse box? and how hard is it to change the engine plug?
  • euroshark
    • Apr 2006
    • 3491
    I used an E24 harness and had to splice all of the wires at the C101 plug.
    If you have an '87 harness and an '88 car, if you have to splice anything it should be super easy.
    • george graves
      • 20003
      '89 325is + m20 harness + m30b35 + 1988 635cis ECU(motrontic 1.1) = smile
      Originally posted by Matt-B
      • SpunkyE30nOk
        • Jun 2006
        • 228
        THE C101 plug is the plug on the engine right? where you would hook up a diagnosis machine? How did you hook the engine harness up to ya fuse box?
        • JoeMadoo
          • 936
          88 E32 Manual Harness in the 86 E30, just because I like the plastic cover over the injectors and no need to move or lengthen any of the connectors... Also the m20 harness doesn't have the pulse connector for the #6 spark plug wire for the later M30's.
          '86 E30
          '05 E53 X5
          '72 Firebird
          '10 Prius
          '03 Tundra
          • SpunkyE30nOk
            • Jun 2006
            • 228
            my motor is the gen II m30 m30b34 I think 86 735i
            • Funkmasta
              • May 2004
              • 7185
              I used the M30 harness, but if I did it again, I would look into using the M20 harness. It was just difficult finding the *correct* diagrams for my application. (87 M20i, and 88 M30 3.5 are both freak parts for those years, so most manuals and references don't have the correct diagrams.)
              Joe Funk -- Portland Oregon
              That Guy.
              03 X5. 3 liter obviously.
              • SpunkyE30nOk
                • Jun 2006
                • 228
                I think I'm going to pick up a spare m20 harness that way i can compare it hooked up in my e30 now to how it is going to be on the m30 motor.
