M30 swap...quick confirmation.
  • njansenv
    • Oct 2007
    • 32
    Hello all. I'm doing my background checks before dropping the coin on an e28 drivetrain for my 2 dr 1987e with 5 speed and would like confirmation that:
    1. I need the e34 oil pan and pick up
    2. Need mounts
    3. Need Rad
    4. Need engine and trans and ECU, use stock driveshaft IF the e28 trans is a 1 pc unit.
    5. Exhaust work
    So, all I need is mounts, rad, and oil control stuff? I found the e28 setup locally (engine, trans, wiring, ecu) for CHEAP.
    Thanks for your time, I REALLY appreciate it.
    Nathan
  • george graves
    • 19996
    Looks like a start of a list....
    K&N air filer or stock e34 m30 filter housing.
    Coolant hoses (mix of m20 and m30)
    Not sure what you are going to have to do for tranny mounts...
    Electric fan
    Originally posted by Matt-B
    • euroshark
      • Apr 2006
      • 3491
      I used only M30 coolant hoses, and the stock E24 transmission crossmember and mounts. Also, the early M30 air box DOES fit, though it's tight... I definitely recommend the E32 / E34 M30 air box. Cold air intakes rarely work as intended.
      • Lurker27
        • 821
        I think a cheapy "CAI" is fine if you remember the important part is the heat shield.
        '89 335is +turbo
