2 Questions: Throttle Bracket, E36 Rack
  • talltorontoguy
    • Apr 2006
    • 267
    Throttle cable bracket:
    In Jared's guide he mentions that you need to pick up an m30 throttle cable bracket as the E30 one will not fit. I'm assuming I use the E30 throttle cable with an M30 bracket. Does anyone have any pictures of how the throttle cable setup should look? part #?
    E36 Rack:
    The tolerances between the oil pan and the steering rack are apparently quite tight. Has anyone done both the M30 swap and the E36 rack swap successfully? I want to put the E36 rack in but don't want to have a problem fitting the engine in.
    Thanks guys!
    Rod
    Winner - Best Engine, Bimmercruise 2010
    Runner Up - e30 Wild Category, Bimmercruise 2010
    Winner - Best Cabrio, Trillium @ Tedfest 2011
    Winner - e30 Wild Category, Bimmercruise 2011
    www.vertnation.com
    My car in Berlin Klassic promo video
  • E30SPDFRK
    • 5713
    I would like to know too as I am about to buy a 95 M3 rack.
    Byron
    Leichtbau
    • ldsbeaker
      • Aug 2004
      • 3098
      oops, wasn't really thinking about that. Just assumed it would fit.
      Slicktop City!
      • oldskool3
        • Mar 2005
        • 401
        if you read through the e36 rack swap thread in the DIY section I think it has some info in there as to which one is the best to use. I think it was the m3 rack because it was smaller but I could definetly be wrong.
        Photoshop by O 16581 72452 5
        • JoeMadoo
          • 936
          You can use the e30 throttle cable...
          '86 E30
          '05 E53 X5
          '72 Firebird
          '10 Prius
          '03 Tundra
          • SpunkyE30nOk
            • Jun 2006
            • 228
            The e36 rack should fit w no problems. The issue w the e36 racks is that you have to modify the steering knuckle for it to work.
            • speedhop
              • 1509
              I can tell you hopefully within the next month 100% sure...I'm thinking that it'll be just fine.
              If it doesn't fit, I'll be upset.
              www.ryanwhopkins.com
              • oldskool3
                • Mar 2005
                • 401
                same. I know that they are thicker than the e30 racks but I think someone has already tested it and it fit.
                • talltorontoguy
                  • Apr 2006
                  • 267
                  It's a lot easier to pull the rack when there is no engine. If anyone can confirm 100% it will fit it will put all our minds at ease.
                  www.vertnation.com
                  • talltorontoguy
                    • Apr 2006
                    • 267
                    I've confirmed that the E36 rack with M30 engine combo does work with a fellow M30'er
                    www.vertnation.com
                    • Funkmasta
                      • May 2004
                      • 7185
                      good to know, I figured it would...
                      Joe Funk -- Portland Oregon
                      That Guy.
                      03 X5. 3 liter obviously.
