quick swap electrical confirmation
  • bimmer_adam69
    • Mar 2006
    • 223
    hey guys, finally ready to do the swap next weekend.
    please read this and tell me from hyour experience if i got it right...
    87 325is with 89 e32 driveline.
    im using the m20 harness with the m30 ecu. and should be a pretty easy plug and play right?
    which sensor wires must I extend? and any suprises or tricks you guys encountered along the way?(electrical wise)
    any info would be awesome....remeber im talking m20 harness:)
    thanks!
    M stands for Money:hitler:
  • bimmer_adam69
    • Mar 2006
    • 223
    mmmmmm bump!
    • SpunkyE30nOk
      • Jun 2006
      • 228
      from what i understand I think you lengthen the 1st injector wire and the wires for the coolant temp sensor. Maybe its both the coolant temp sensor and the temperature switch. On my m30b34 they are in a row on the water housing for the thermostat. The two sensors that is.
