M30 Swap... how to get engine + transmission in as one unit?
  • talltorontoguy
    • Apr 2006
    • 267
    How hard is it to get the M30 and it's transmission into the engine bay as a single unit without removing the rad support? Any tips?
    Winner - Best Engine, Bimmercruise 2010
    Runner Up - e30 Wild Category, Bimmercruise 2010
    Winner - Best Cabrio, Trillium @ Tedfest 2011
    Winner - e30 Wild Category, Bimmercruise 2011
    www.vertnation.com
    My car in Berlin Klassic promo video
  • euroshark
    • Apr 2006
    • 3491
    Drop the subframe and bolt it to the engine while the engine is on the hoist. Then slide the whole thing under the car, with the hoist disconnected of course, reconnect the hoist when the engine is under the car, lift it up into position and bolt the subframe back in. I did it that way in about 30 minutes.
    • Mastrcruse
      • Sep 2005
      • 5340
      or...put the hoist on the front hook only and you will have to help hoist the entire package about 3-4inches over the radiator support.
      Then jack up the front of the car, while lowering the motor and the rest you will have to determine (what has to go up and down) while you are putting the motor in.
      • SpunkyE30nOk
        • Jun 2006
        • 228
        I will be doing that when i start my swap. I will have access to a lift to so it should be a piece of cake. Once you lifted the subframe back up w the drivetrain did you have to make alot of adjustments to get and hoses, wiring to line up correctly?
        • Shoomakan
          • Sep 2007
          • 123
          I did that, but due to a lift that wouldn't go the way I wanted it, I ended up denting the firewall some.
          I'm guessing it's easiest the way the dudes said so, it just wasn't all peaches with me. Good luck, dude!
          • SpunkyE30nOk
            • Jun 2006
            • 228
            to sit the motor further back you have to take a few whacks at the firewall....killin 2 birds w 1 stone my friend ;)
            • talltorontoguy
              • Apr 2006
              • 267
              How do you get the car high enough to "slide the whole thing under the car"? I'm guessing that you have the car on a lift, raise the car up, put engine in place, lower car, fine tune placement with engine hoist from above?
              www.vertnation.com
              • euroshark
                • Apr 2006
                • 3491
                We did it with the rear wheels on ramps and the front of the car sitting on jack stands, nothing too fancy. You just slide the engine / subframe combo under, get it roughly right, lower the car to a more workable height, and reconnect the hoist. We were very surprised at how easily the who unit went in, and like I said, it was bolted up within about 30 minutes.
                • talltorontoguy
                  • Apr 2006
                  • 267
                  Ok, well I'll give it a shot. I don't have the steroid enhanced jack stands, mine wouldn't nearly get high enough for the engine to clear... but I'll figure it out!
                  Thanks!
                  Rod
                  www.vertnation.com
                  • Jean
                    • 18228
                    You need to open a shop (E30 M30 Swaps in 30 minutes or your money back) :p
                    • george graves
                      • 19995
                      Really...
                      You can drop a m30+tranny into a e30 with a hoist. You just need the car a foot or 2 off the ground.
                      With out the tranny is much easier(still not easy).
                      Originally posted by Matt-B
