m30 swap choice
  • Rodoni
    • Sep 2007
    • 1838
    m30 swap choice
    is an 88 e28 m30 a good canidate for an m30 swap?its out of a 88 535is Eventually it would get turbo'ed... I'm just starting to research the swap.
    ***Affordable Powder Coating Here:***
    http://www.r3vlimited.com/board/show...=1#post2074588
    *** Bay Area/NorCal Fender Rolling Here: ***
    http://www.r3vlimited.com/board/show...29#post1989029
    ***If you've ever bought anything from/dealt with me please add feedback!!:
    http://www.r3vlimited.com/board/showthread.php?t=137611***
    Thank You!
  • E30SPDFRK
    • 5713
    Yes. You will need to modify the firewall to make it fit, but if you take the cats off the b34's they make almost as much as the b35's do.
    Byron
    Leichtbau
    • Jonsku
      • Oct 2004
      • 566
      E28 535 is 218hp without cats or 184hp with cats, no idea which ones you have there in the states.
      E34 535 makes 211hp with cats, and has bigger inlet valves so it's better option for turboing if you want to take it to the limit.
      But basically it's the same which of the 3.5l M30:s you turbo, you'll get lots of power anyways :)
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
      • george graves
        • 20003
        The e28 will have the water pipe on the back of the head, you may need to clearance it. BTW, Joe's/funkmaster mounts (a far better choice than e30.de IMHO) might not need it. If you do - it is a painless 2 min job that involves a hammer. (and if you think that is scary, you should see what alpina did to the uber rare Z4 to mod it.)
        I could be wrong, but I think everything after a set date(82/83?), was 50-state legal here - meaning they have a cat. Only a gray market car that slipped past won't have cats.
        I do kinda refute the horse power claims you posted. I've read them every where too. But really, a cat doesn't choke a motor that much.
        218 - 184 = 34 HP.
        Unless they changed something else (EURO vs US compression and/or cams), there is no way in hell a cat is going to rob you of 34 horse - unless it's a TINY TINY cat - and I've never seen BMW use anything that doesn't flow
        Now if we are talking early e12 exhaust gas recirculation - maybe you could loose 34 HP - but not with a cat.
        Anyone else find the numbers funny?
        Originally posted by Matt-B
        • Jonsku
          • Oct 2004
          • 566
          218 - 184 = 34 HP.
          Of course catalysator in the exhaust is not the only change BMW made to 535 for it to lose 34hp. It has different ECU, compression ratio is somewhere around 8:1 (218hp version 10:1) and exhaust-manifolds & pipes are smaller.
          Btw, you don't need to hammer firewall to make M30 fit with 535 radiator..
          - E34 M5 (x 2) -
          • De //m3
            • 165
            Yeah the cat is good for aout -10 HP, The compression makes a at least another -10 HP, and then the ECU adds some - HP as well
            2001 330i - In the garage.
            1986 335is - 325e with Euro 735 M30B34, Under Construction.
            1989 E30 ///M3 - Sold.
            1975 2002 - Sold.
