m30b35, getrag 260/6, what driveshaft?
  • Doughnut
    • Oct 2007
    • 869
    Hey guys,
    I'm getting a 260/5 getrag (or 260/6 getrag) for my m30 swap, and engine postion 2, how do i go about the drive shaft? Do I have to get one custom built out of two, or can I buy one that just bolts right up, I read somewhere that a e30 320i drive shaft bolts up, any ideas??
    Thanks.
    ///Monstrosity. (OO≡≡[][]≡≡OO)
    Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
  • Jonsku
    • Oct 2004
    • 566
    I had E28 528 front piece and E30 325 rear piece. It was a tight fit but worked fine.
    Of course had to get it balanced.
    - E34 M5 (x 2) -
    - E30 V8 Cabrio "Kylpyamme" -
    - Alpina D10 Touring #33/94 -
    - E46 318i Touring -
    - Toyota Hiace 4wd -
    • Doughnut
      • Oct 2007
      • 869
      What do you mean by "tight fit?" Was there no splines on the slip joint present?
      • SpunkyE30nOk
        • Jun 2006
        • 228
        i have also heard you can use a driveshaft from a 325e auto...but that may be for pos 3 not 2...anyone else know more on that?
        • Doughnut
          • Oct 2007
          • 869
          This is taken from another thread in ecca.com :
          I think there was one guy who had engine postion 3, and used the m30 front shaft attached to the 325e auto rear shaft (tailshafts have 2 pieces, disconnect at center bearing). That is the only person i have herd of that has not had a custom shaft made.
          Seems you need to get two halfs.
          • Doughnut
            • Oct 2007
            • 869
            Post #107, he used his stock drive shaft but has "out of balance" issues, ended up get a full custom tail shaft.
            Can anyone elaborate on what is going on?
            • Jonsku
              • Oct 2004
              • 566
              I mean that the splines were "all in", so the engine couldn't have been furher back, otherwise the driveshaft had to be shortened.
              Hopefully you understand what i mean :)
              Now i've different gearbox so i had to get the driveshaft shortened, costed about 40€ so no big deal. You've to get the driveshaft balanced anyways, so get it shortened at the same time if needed.
              - E34 M5 (x 2) -
              • Doughnut
                • Oct 2007
                • 869
                Ah I get ya, Cheers.
