Im using the e34/e32 auto harness and was doing some research on e30.de. I found the wires I think I need....
e34/e32 harness:
#1 - BL: alternator
#4 - BR/VI: coolant sensor (use e30's)
#5 - BR/GN: oil pressure switch/sensor
#7 - GN: ignition coil
#9 - SW: rpm signal/output??? need this?
#13 - GN/VI: 12v to fuel pump relay
#18 - SW/GE: starter
Any thoughts??? Im missing one wire.... which one is it? Do I have it right? Also I was looking at my cars harness and its colors and tried tracing them down! I have a 84' 318i l-jetronic 8pin connector.
my harness chassis side:
#1 - BL : Alternator
#4 - BR/VI : Coolant temp sensor
#6 - GN/GE :
#7 - R/VI : Fuel pump
#8 - SW/GE with another small SW/GE : Starter
#10 - GN : Coil
#16 - SW/BR : Oil pressure switch
#17 - WS/BL :
German: http://wp1016621.wp027.webpack.hoste...105/f00105.htm
English: http://translate.google.com/translat...F8&sl=de&tl=en
e34/e32 harness:
#1 - BL: alternator
#6 - GN/GE :
#10 - GN : Coil
#17 - WS/BL :
