M30/E30 Driveshaft Question
  • talltorontoguy
    • Apr 2006
    • 267
    I'm using the following setup:
    Car is 88 E30 325i vert
    M30B35 engine (E34)
    260/6 transmission (E34)
    Engine Position 3 Mount
    Stuck on driveshaft. Research indicated that the front of E34 and rear of E30 325i can be mated. My E34 driveshaft doesn't disassemble the same way as the E30 one and cannot be mated to the E30 one.
    What driveshaft or combo of driveshafts do I use?
    325e > 6/86?
    Rod
    Winner - Best Engine, Bimmercruise 2010
    Runner Up - e30 Wild Category, Bimmercruise 2010
    Winner - Best Cabrio, Trillium @ Tedfest 2011
    Winner - e30 Wild Category, Bimmercruise 2011
    www.vertnation.com
    My car in Berlin Klassic promo video
  • BenM
    • 2184
    I think you can use the one from a 6>86 and later 325e/es. It has the larger (3.12" I believe) guibo.
    HTH.
    Originally posted by BillBrasky
    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
    1991 318i Alpine II - S50/5-lug swapped - track car
    1989 325i Cirrusblau - Daily
    1970 2500 - Malaga over Grey Cloth
    2012 F350 6.7PSD
    • Funkmasta
      • May 2004
      • 7185
      I don't believe in the different "positions" so I am not sure where, exactly, "3" is... but,
      You should be able to use the "e" driveline, it will at least be close. You may need to use a driveline from an E36 328, since that will keep the CSB in the correct spot, and you can shorten or lengthen the front half to some degree
      Joe Funk -- Portland Oregon
      That Guy.
      03 X5. 3 liter obviously.
      • Jonsku
        • Oct 2004
        • 566
        325e (6/86 onwards) / 324td / M3 / 320iS driveshaft has the 96mm front you need for that.
        But why you don't just cut the E30 and E34 front parts and get them welded together? You won't find driveshaft in the correct length (pos. 3 is so far back..) so you need to get the ds. shortened and balanced anyways..
        - E34 M5 (x 2) -
        - E30 V8 Cabrio "Kylpyamme" -
        - Alpina D10 Touring #33/94 -
        - E46 318i Touring -
        - Toyota Hiace 4wd -
        • talltorontoguy
          • Apr 2006
          • 267
          The 325e driveshaft worked perfectly in conjunction with an E34 535 guibo. No need to weld or shorten the driveshaft.
          www.vertnation.com
