Driveshaft issues
  • E30SPDFRK
    • 5716
    Driveshaft issues
    I'm nearing the end of my swap and I still don't have the driveshaft figured out. I was planning on using either the front of an e28 with the back of mine or swapping the output flange on the tranny and running my factory one, but after measurements, neither of these will work.
    I measured from where the engine mounts bolt to the subframe to the output flange of the tranny. The eta combo was around 38.5" and the b35/260 combo was only 34". Does this sound correct? Both the e28 and e30 shafts were about 24" from the back of the guibo to the center of the u-joint, so I need one that is about 28" long.
    What are my options here? I've been told an 87e driveshaft will work, but there are none around here. Would the front of an e34 535i shaft work? Anything else?
    Thanks
    Byron
    Leichtbau
  • talltorontoguy
    • Apr 2006
    • 267
    The front of an E28 535 driveshaft with the back of your 325i driveshaft "may" work.
    The E34 driveshaft I had could not be disassembled the way the E30 and E28 shafts can. Early E34s may be different.
    I used an E30 325e driveshaft unmodified. I have an M30B35 (92) in position III with 260 transmission and stock diff.
    Rod
    Winner - Best Engine, Bimmercruise 2010
    Runner Up - e30 Wild Category, Bimmercruise 2010
    Winner - Best Cabrio, Trillium @ Tedfest 2011
    Winner - e30 Wild Category, Bimmercruise 2011
    www.vertnation.com
    My car in Berlin Klassic promo video
    • peerless
      • 285
      Ok take your drive shaft and measure it from the rear flange all the way to the front flange, write down that number.
      Install the flex disk on the back of the trans, measure from the face of the flex disk to the differential flange, write down that number. This is how long you need your driveshaft.
      Subtract the length you need from the actual length of the driveshaft, this is how much it needs to be shortened. You have the middle slip yoke so you have a little fudge factor.
      The M30 swap I did we used a 265 transmission. The driveshaft was a Mid 86 eta with the big flange. We had it shortened 2". The driveshaft was fully rebuilt with new u-joints, shortened, balanced for $350
      You have to make your own measurements and call a driveshaft shop and make it happen.
      • E30SPDFRK
        • 5716
        My driveshaft needs to be longer though going by my measurements. I measured just the fronts of my e30 and e28 driveshafts and they were both the same length.
        What part of the e34 shaft was different?
        Byron
        Leichtbau
        • Funkmasta
          • May 2004
          • 7185
          Byron, the motor is in?
          Joe Funk -- Portland Oregon
          That Guy.
          03 X5. 3 liter obviously.
          • Funkmasta
            • May 2004
            • 7185
            The E34 driveline is the different style, where the slip is in the rear joint, instead of on the shaft
            That Guy.
            • E30SPDFRK
              • 5716
              Not in yet, should be in tomorrow if I can get the engine bay painted tonight. Do my engine/transmission measurements sound right? I don't know why everyone else talks of shortening there driveshafts when mine needs to be lengthened.
              Byron
              Leichtbau
