Oil Pan and Pump for M30 Swap?
    Hey, Im dropping in a Euro '72 735 M30B34 into an 86 325es. Using engine brackets form Funkmasta...Will my pan fit, or do I need to get an E34 pan and pump?
    2001 330i - In the garage.
    1986 335is - 325e with Euro 735 M30B34, Under Construction.
    1989 E30 ///M3 - Sold.
    1975 2002 - Sold.
    You will need the pan and pump from an E32 735i/il or E34 535i. The B35 sump sits way out front, whereas the B34 sump is maybe 1/3 of the way from the front of the engine, and because of that it will interfere with the subframe / steering rack.
      The pumps are the same... You need the E34 M30 pickup.
      Slicktop City!
        Where does one find just the pickup? I've never checked with a dealer, but I am fairly sure I've never seen any on Ebay. Certainly might save a few bucks if you can find one though!
          I was actually able to find one for pretty cheap. Lucked out. (for once)
          Slicktop City!
            talk to the funk, he hooked me up with mine ASAP
            and its from an M5 ;)
            Need Illustration or Design work? www.robbiebyerly.com
              I have 2 pans and pickup packages... :)
              Joe Funk -- Portland Oregon
              That Guy.
              03 X5. 3 liter obviously.
