Another m30 swap almost done.
  • BoostMW
    • Nov 2007
    • 183
    I started this this spring and after much delay its finally road worthy, I have a 1987 325e and transplanted this e32 m30b35 in with a getrag 265. I had flywheel shaved down to 11 lbs from about 16 lbs and installed the generic chip you see on ebay that claims like 40 hp. The car is quick and feels pretty much the same a stock e30 with more power. I removed a tcd turbo kit from my e28 DD and had plans of putting it in here but with about 225 whp it feels fast.Well anyway here is a few pics. I know the zip tie on the throttle cable will be my next fix,lol
  • kronus
    • Apr 2008
    • 13032
    You guys make this stuff look easy. Props!
    cars beep boop
    • hendrixvodu
      • Jan 2007
      • 2514
      ready to come do mine?
      -His-
      87 e30 325i
      87 e24 m6
      05 e83 x3
      94 e32 740i 5spd
      -Hers-
      89 e30 325i
      18 f48 x1
      • RickSloan
        • 2401
        it is easy as long as you have lots and lots of patience!
        Looks good man! were did you get the 335 badge??? i wanna put one on
        Need Illustration or Design work? www.robbiebyerly.com
        • hendrixvodu
          • Jan 2007
          • 2514
          i need my e28 radiator still and harness ....but its a bit scary to me haha
          -His-
          87 e30 325i
          87 e24 m6
          05 e83 x3
          94 e32 740i 5spd
          -Hers-
          89 e30 325i
          18 f48 x1
          • speedhop
            • 1509
            How and why did you get the auto tps to work?
            www.ryanwhopkins.com
            • BoostMW
              • Nov 2007
              • 183
              thanks for the props. The badge is from the e90 335i. What is the issue with using the
              TPS from a auto trans car? I used e32 auto harness and dme but and have plans of changing the variant code of the dme to a manual trans dme.
