Hose Question
  • LKTe30
    • Dec 2004
    • 151
    Hose Question
    The 2 hose connections on the intake manifold under the throttle body, does the bigger of the 2 connect to the valve cover, and the smaller one is just a vaccum line?
    mike@lookoutdrift.com
  • el_gringo
    • Mar 2008
    • 299
    realoem.com will show you exactly what should be on your car. take a peak, sir.
    also remember, not every e30 has the same engine. so when you ask something related to your car, give us a ideal of what were looking at... a signature will usually help that issue out.
    • LKTe30
      • Dec 2004
      • 151
      realoem doesnt show it asnd its for a m30 thats why its in this section
      • StereoInstaller1
        GAS
        • 22679
        Mike, I see the logic in assuming that since you posted in the M30 swap section, that would be all fine and stuff...buuuuuuut....most of us read by hitting the "New Post" button, so we don't really realize where we are looking.
        Oh yeah, I have nothing to offer on that vacuum line, either. Sorry!
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • speedhop
          • 1509
          There should be 3 outlets, 2 vacuum and 1 larger outlet. 1 small goes to charcoal canister and purge valve, the other small outlet goes to your fpr.
          The large outlet goes to the icv which hokes straight into the tb hose. This is all assuming that you have the b35 engine.
          www.ryanwhopkins.com
          • LKTe30
            • Dec 2004
            • 151
            Thanks that is what i needed to know
            • el_gringo
              • Mar 2008
              • 299
              my point... sorry i didnt make it clear
