hoses hoses hoses
  • norwood e30
    • Mar 2007
    • 442
    hoses hoses hoses
    Ok i have a e32 735i motor with 80k on it. So we should all know what my plans on doing with it am i right? I narrowed everything down but i wanted to know if anyone here would know what year and model for of the correct coolant hoses i need for this winter project? if so post or pm me thanks.
  • euroshark
    • Apr 2006
    • 3491
    I used all of the same hoses from an E24. I believe everything from an E32 should work as well assuming the heater valve is in the same spot above and slightly toward the fender from the starter.
    • norwood e30
      • Mar 2007
      • 442
      I was thinking the same thing but wasnt sure.
      • norwood e30
        • Mar 2007
        • 442
        Ok what year should work good? I was gonna go with a E24 6/87 year At bavauto.com or pelican parts.com one of the two. but bavauto has two different types of upper and lower rad hoses? whats should i do i have the e28 535i radiator already today.
        • E30SPDFRK
          • 5713
          I used all e34 parts. The thermostat to wp is the only one that didn't require modification though.
          The lower radiator hose needed to be lengthened, the upper one needed to be shortened, and the lower thermostat hose had to be cut short. I used the e34 coolant overflow tank too though.
          Byron
          Leichtbau
