B34 Crank Bolt ( socket size?)
  • R3V
    • 63
    Do you know what's the mm size for the B34 front main crank bolt?
    It's much bigger than 30mm, i need to find out the socket size to buy.
    Thanks!
  • xlr8rbob
    • Apr 2008
    • 302
    if its the same as the b35, it should be a 32mm. iirc
    www.strictlyea.com
    • euroshark
      • Apr 2006
      • 3491
      32 sounds correct, it's a big bastard. Also, the torque spec is around 325ft/lbs so you MAY have to wait until it's in the car and connected to the transmission before you can properly torque it.
      • R3V
        • 63
        Great, thanks alot guys!
        I'll go get it.
        • Good & Tight
          • Apr 2004
          • 2057
          36mm
          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
          ____________________________
          E-mail Panayiotisx2@gmail.com
          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
          • R3V
            • 63
            oops, i just bought 32mm.
            It's #5 on this picture :
            It doesn't say the size.
            • euroshark
              • Apr 2006
              • 3491
              Aw shit. lol. Sorry dude, collective failure... We aren't always 100%!
              • xlr8rbob
                • Apr 2008
                • 302
                my bad. hope you kept the receipt.
                if you have access to an impact, that should pop it off no problem.
                only took one hit to get that bad boy off.
                www.strictlyea.com
                • De //m3
                  • 165
                  It is also very close on the standards scale, I want to say 1 5/8" but not positive. I had one huge socket laying around and it just happened to work.
                  2001 330i - In the garage.
                  1986 335is - 325e with Euro 735 M30B34, Under Construction.
                  1989 E30 ///M3 - Sold.
                  1975 2002 - Sold.
                  • R3V
                    • 63
                    Finally found 36mm, perfect match.
                    Thanks guys!
