Does anyone have experience putting in a large case diff into an e30? Besides swapping the rear cover, it should be bolt on?
Large Case Differential
will the cover fit is what I am wondering...
I am remembering something being posted on Mye28 about it and for some reason I am thinking you can't but I maybe be wrong...
on one I remember the drain plugs are located one atop the other and on the other one faces rear and one towards the drivers side so I don't know if that would be a problem...
Just curious to know why you wanna put in the large case diffy
But like you said, if there's alot of custom work I wont bother.'86 E30
'05 E53 X5
'72 Firebird
'10 Prius
'03 Tundra
Originally posted by JoeMadoo View PostDoes anyone have experience putting in a large case diff into an e30? Besides swapping the rear cover, it should be bolt on?
Originally posted by JoeMadoo View PostThe cover won't, thats why the e30 cover goes on right? I'm just curious about the physical size of the differential
Originally posted by e30_kid89 View PostJust curious to know why you wanna put in the large case diffy....If Otis is putting out ~370ish @ the wheels with a medium case i think it should be fine.
The larger diffs have a different bolt pattern and stuffs and my not even fit in with out doing some custom work.
Originally posted by JoeMadoo View PostWhy not? I know the medium will work but I'd rather have something that I know will work for 10x longer once I put in the turbo.
While the large case is a bolt-in for E23/4/8, it IS NOT for an E30.
It can be done, but Major PITA, and... arguably no real need?
The E30 is light, and compared to the high power and heavy weight of the E24 M6, and E28 M5, the large case is a little unnecessary.Joe Funk -- Portland Oregon
That Guy.
03 X5. 3 liter obviously.
Originally posted by AlpineBlanco80 View Poste28 3.25 lsd fits swapping the cover and flanges correct?
I had both my e30's "8 bolt" rear cover diff and my e28's "8 bolt" rear cover diff next to each other and can't remember if the bolt pattern lined up (to swap the rear covers). I know the input flange was fine (from the e30's tailshaft) the output flanges were definitely wrong (swap for e30 ones).
Question is, Is there two types of 8 bolt rear covers? (one slightly bigger than the other)? What diff is in the e28, large or medium?
After all the threads I've read on this subject I'm still rather confused:|///Monstrosity. (OO≡≡[][]≡≡OO)
Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
